off-road Y pipe for 89 Formula 350 questions
Old Feb 8, 2010 | 12:41 AM
Linson's Avatar
COTM Editor (Retired)
Car: 89 Formula 350, TTA
Would deleting the cats trigger an error code?
Could I buy a Tubular Exhaust System for a single-cat car (which I believe comes with an off-road Y pipe) and run that?
Would I need to create some additional O2 sensor bungs?
Thanks.
Old Feb 8, 2010 | 01:11 AM
Guest
Guest
Posts: n/a
Re: off-road Y pipe for 89 Formula 350 questions
No.
No, because it will not come with an off-road pipe, at least not that I am aware of.
There is only one o2 sensor.
Old Feb 8, 2010 | 02:51 AM
Linson's Avatar
hello. thanks for your input. check this out.
http://www.jegs.com/images/photos/300/350/350-68723.jpg
this is the Edelbrock TES that is for a 86-90 TPI car with single catalyst. it has what appears to be an off-road Y-pipe. i could be mistaken, suposing the single cat starts where the Y in the picture ends.
http://www.jegs.com/images/photos/300/350/350-68763.jpg
this one would be the TES for a dual-cat system. it lacks a discernable Y-pipe.
so, regardless of whether it is a stock dual or single cat setup, there is only one O2 sensor?
thanks again.
Old Feb 8, 2010 | 04:26 AM
Drew's Avatar
Those headers (and every other for our cars that I'm aware of) end just before the location of the stock catalytic converter. The idea being that you cut your catalytic converter off the existing Y pipe and clamp it on the headers.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
okfoz
Mar 9, 2017 02:35 PM
redmaroz
Aug 16, 2015 11:40 PM
