some 305 TPI LB9 questions about aftermarket stuff...
Old Feb 11, 2010 | 07:13 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, well I've done a search and couldn't find much on the matter. Anyway, what's are a good pair emissions-compliant (for CT) headers for 305 TPI engine? I also would like to possibly bypass the smog pump (probably with shorter belt, what size would that need?) for now and gut the cat, since I bet those things are taking away from the engine, and my next emissions test is due in 2 years. Any way to plug up the holes in the headers for those things for the meanwhile? Would that help with gains or is that just a waste of time? What diameter exhaust would you recommend too? Something that's good bang for the buck.
And after that's out of the way, what's a good intake/cam combo for a 305? Would this stuff be worthwhile?
Old Feb 12, 2010 | 04:27 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: some 305 TPI LB9 questions about aftermarket stuff...
SLP has or had a nice set of stainless shorty headers and Y-pipe that is very good quality and easy to install as far as headers go.
This is a very good hydraulic roller camshaft for a 305.
http://www.lingenfelter.com/mm5/merc...egory_Code=C30
Old Apr 1, 2010 | 05:40 PM
aks's Avatar
aks
Car: 92 Z28
Hey, sorry to bring up an old post but figured it would be better then to start a new one.
I want to put a cam in my 305 also to wake it up a bit.
Would I have to do any other modifying or tuning for that cam to work?
and is that better then an lt1 cam?
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
