Combustion Chamber Size
Old Feb 17, 2010 | 08:46 AM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Transmission: 97GM BW T-56
Axle/Gears: 9", Moser 31 Splines 3.73s Trac Loc
I'm sure this has been answered a million times somewhere in the boards, but can someone please tell me the size of the chambers on the LB9.
I've got a 305 TPI that I'm thinking of putting some Pro1s on, 64cc chambers, but after doing some looking, I'm thinking it's gonna drop my C/R a little too much. Any facts and comments appreciated.
Old Feb 17, 2010 | 11:16 AM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Re: Combustion Chamber Size
Hey, I believe they are 58cc. Did you do a compression calculations with new heads? It might not be as big of drop as you are thinking, maybe 0.5-.75? Pro Comps are aluminum so would be best to run high compression like 11.0. Check out chart on this page showing power differences from changing rations. Going from 10:1 to 9:1 ratio will cost you 2.9% in power. So that would be 6-7 HP for 200 HP engine.
http://www.popularhotrodding.com/tec...ech/index.html
Here is a good compression calc that figures out dynamic compression. Change in dynamic compression would be more important to know. Need data on heads and cam to get results.
http://www.empirenet.com/pkelley2/DynamicCR.html
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
