can this realy be done?
Old Feb 11, 2010 | 08:12 PM
thegoochking's Avatar
I came across a video on youtube of a gta with what looked like a mini ram intake but the poster stated all he did was attach the k&n filter dirextly to the throttle body and removed the mas air flow sensor. He also said it runs better now. Is this possible and if so would you get any performance gains by doing so?
Old Feb 11, 2010 | 08:52 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Re: can this realy be done?
Possible yes, will the car run, yes. Will it run better no.
Old Feb 11, 2010 | 09:05 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
You can convert to a 90-92 TPI ECM, they don't use a MAF sensor.
Old Feb 11, 2010 | 09:07 PM
So no performance gain. Would it run any worse? How would I attach the filter directly to the throttle body if I were to do it. I think if it doesn't take any performance away it would create some more space in the engine bay. And it looks prety cool
Old Feb 11, 2010 | 10:00 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Without converting the ECM the car will go in limp mode pull a ton of timing and generally run like poo.
Old Feb 11, 2010 | 10:15 PM
redcorvette's Avatar
Car: 85 vette
Engine: 427 SHP block,AFR 210,MiniRam
Transmission: TKO 600
Axle/Gears: 3:07
To get a quick idea of how much performance you will gain by removing the MAF, just unplug the MAF and drive the car. Unless you modify the ecu you won't be happy.
A problem with mounting a filter directly under the hood is the engine will be breathing the warmer underhood air. Companies make a lot of money selling cold air kits because using cooler air from outside can be worth a few extra hp. Try searching "cold air kit" on this forum.
Old Feb 11, 2010 | 11:05 PM
has anyone ever tried to fabricate a ram air that would suck air from the hood vents on a gta hood? That would be prety sweet.
Old Feb 12, 2010 | 12:23 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
alot have tried, very very very few have succeeded, mainly because the vents and the intake don't align properly...
Old Feb 17, 2010 | 12:59 PM
are there photos online of any that have pulled it off?
mikey8494
Aug 22, 2015 07:57 PM
NORT
Apr 27, 2001 08:56 AM
Matt1980
Mar 5, 2001 11:35 AM
NORT
Feb 26, 2001 10:47 PM
Crash
Oct 31, 2000 07:22 PM
