SLP runner question
Old Feb 18, 2010 | 11:58 PM
intmdatr3's Avatar
Car: Monte Carlo SS
Engine: 305 W/TPI
Transmission: 2004r
Axle/Gears: 3:73 Posi
SLP runner question
I am thinking of buying a set of SLP runners for a 89 Tpi setup. I am running a 87 Tpi setup and was wondering will these fit my setup. Thanks for any info.
Old Feb 19, 2010 | 01:38 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: SLP runner question
Hello intmdatr3!!
IIRC 85-88 has the cold start valve hole, and 89-92 doesn't!! That should be the determining factor!!
As for your particular set up, they won't work, if they were 88's, then yes, you would be good to go!!
This info is from slponline.com
Just my 's!!!!
Old Feb 19, 2010 | 12:34 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
You will have to plug up the cold start portion. Not a big deal but needs to be done for use with the later TPI systems other wise you will have a big air leak.
tazs2000
Jul 15, 2017 08:44 AM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
redmaroz
Aug 16, 2015 11:40 PM
