TPI swap
Old Feb 27, 2010 | 04:29 AM
houseumbrella's Avatar
Car: 1992 Camaro RS
Engine: 305 Throttle Body Injection
Transmission: Turbo-Hydramatic 700R4 four-speed
TPI swap
i have a plenum, runners and intake manifold, i'm thinkin all i need is the gaskets, fuel rail, fuel injectors, throttle body and air filter to complete this swap. would my camaro run well (or even run at all) if i did this swap without swapping any electrical makeup?
Old Feb 27, 2010 | 01:39 PM
Vader's Avatar
Re: TPI swap
You need the ECM to operate the injectors as well as read the sensors, and as a result will need a wire harness tailored to teh TPI system.
You will need a fuel pump capable of delivering 3 BAR (44 PSIG) to the fuel rails and fuel lines which can operate at that pressure.
You will need the power relays for a TPI which may include a MAF power and MAF burnoff relay as well as the fuel pump relay.
There are some fairly detailed instructions posted in several locations on the interwebs.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
