Code 36 Troubleshooting
Old Mar 11, 2010 | 07:22 PM
mdallen8's Avatar
Car: 1988 Firebird Formula
Engine: 5.0L TPI
Transmission: 5 Speed Manual
Axle/Gears: 3.08 Posi
How can I find a diagram (or something like a flow chart) that would show me how to troubleshoot the Code 36 problem. I have an '88 Formula, 305 TPI. I know it has to do with the burn-off circuit, but I can't seem to find any manuals that tell me how to troubleshoot it without randomly starting to replace relays.
Old Mar 11, 2010 | 07:26 PM
yamban's Avatar
Car: 1985 Z28
Re: Code 36 Troubleshooting
this may be of help. I had code 36 a while ago and it turns out my MAF was broken.
https://www.thirdgen.org/service-eng...ht-error-codes
Old Mar 11, 2010 | 07:45 PM
mdallen8's Avatar
Engine: 5.0L TPI
Thanks, but we already know what the code means. We are looking for a troubleshooting diagram (such as a GM shop service manual) to try to determine what needs to be replaced.
Old Mar 15, 2010 | 01:35 PM
bowtie316's Avatar
I hope this is legible. I found it on the internet somewhere some time back. It should give you some idea as to where all the wires go. I can't help much more than that. I also have a code 36, haven't had a chance to troubleshoot.
Old Mar 15, 2010 | 08:50 PM
mdallen8's Avatar
Engine: 5.0L TPI
thanks for your help. just out of curiousity, i have an '88, and this is an '89 ... would it be the same??
Old Mar 15, 2010 | 09:05 PM
mdallen8's Avatar
Engine: 5.0L TPI
... turns out its not really very legible, but thanks anyway!!
Old Mar 16, 2010 | 09:02 AM
bowtie316's Avatar
That's strange, It must loose some image quality through photobucket or Thirdgen.org. I can e-mail it to you if you pm me with your e-mail address.
Old Mar 16, 2010 | 09:06 AM
bowtie316's Avatar
Just as an FYI... I had originally used Napa AR279 relays for both the MAF power and MAF burnoff since they were missing from my harness when I got it. From what I'm reading on here, an aftermarket relay is the most common cause of the code 36. So last night I replaced the MAF power relay with the 14089936 GM relay (this is the round style relay) and so far my code 36 has not come back. Only time will tell, but if that doesn't fix it, I will replace the burnoff relay with the 14089936 GM relay too.
Old Apr 27, 2010 | 10:04 PM
hiller1162's Avatar
Hello where exactly is the 2 relays MAF power and the maf burnoff in the fire wall????? Any help would be great.
THANKS!!!!!!!!!!!!!!!!!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
