Help!! Crankshaft pulley problem
Old Mar 13, 2010 | 04:44 PM
woundupz's Avatar
I have an 86 IROC with the 305 TPI. I am trying to remove the crankshaft pulley but can't figure it out. It has 3 bolts which I unscrewed but the pulley will not budge. There is a bolt in the center of the pulley but I think it is for the balancer..?? Do I need to unscrew that middle bolt to get the pulley off. Any help would be great.
Old Mar 13, 2010 | 05:31 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: Help!! Crankshaft pulley problem
Penetrating oil and a hammer! Be careful not to bend it...
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
I don't really recall... but, i don't think you need to. Of course, it wouldn't hurt to take it out, and see if that makes the difference.
Old Mar 13, 2010 | 05:57 PM
J91's Avatar
J91
You do unscrew the bolt ,I think, hard to remember!
Old Mar 13, 2010 | 09:06 PM
Guest
Guest
Posts: n/a
The center bolt has to come out as well. Then the pulley will come right off.
Old Mar 13, 2010 | 09:13 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Old Mar 14, 2010 | 05:20 AM
J91's Avatar
J91
Thanks. could not remember for sure...
TEEZER TA
Aug 30, 2015 06:35 PM
Navy8125
Aug 22, 2015 07:13 PM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
