different relay question help
Old Mar 19, 2010 | 01:05 PM
littlej2700's Avatar
Car: 1987 firebird formula
Transmission: 5-speed
Alright so i went out and i bought one mr22 which is the power relay and one mr5 which is the fuel pump relay. the mr5 is not like the mr22 its a different style cube and i dont know where it goes.... any help on that?
The other wierd part is that i traced down which relay was the fuel pump by removing the 3 relays and individually hooking them up till the fuel pump primed at the "on" so i was down to burn off and power relays.
Anyway point is my car used to run ok but would kind of sound like it was missing and would stall a lot at stoplights etc but now after messing with the relays it runs amazing with no missing but idles really high and i actually have to idle it down, why would it do that?
Lastly when i was messing with the relays i left the car running and unplugged one and both of the maf power and burnoff relays and the engine didnt act any different, does that mean my MAF is bad? sorry this is so long but it should make sense.
Old Mar 19, 2010 | 01:06 PM
Re: different relay question help
One last question which one of the two MAF relay connectors is a 4 prong connector?
Old Mar 20, 2010 | 12:11 AM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
the burnoff is the 4-wire. And when you say the mr5 is a different style cube i think you got a newer style relay, all relays should look the same on your 87. If you got any more electrical questions try looking at the wiring diagrams on austinthirdgen.org.
RazorN8
Jan 7, 2022 11:44 AM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
