Spark plug wires getting "toasty," any thoughts besides shorty plugs?
Old Mar 22, 2010 | 09:44 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
So I used to run taylor 8mm wires with 90' boots on my old 350 with shorty headers, and never seemed to have any issues. But after running the car the other day through it's first initial runs, the #3 and #5 boots of my MSD 8mm's are toasted pretty bad, #5 being the worst. After looking at some various other plug wires, none really seem to be more heat resistant than the others. I'm running angle plug heads and hedman shorties, just looking for some input, if anyone's had success with a particular brand. I may try routing them close to the block/oilpan vs. dropping down through the primaries from the valve cover. Thanks guys
Will
Old Mar 22, 2010 | 09:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Spark plug wires getting "toasty," any thoughts besides shorty plugs?
Solved similar problem on mine
http://cgi.ebay.com/ebaymotors/Set-o...Q5fAccessories
Old Mar 23, 2010 | 05:34 PM
randyz91's Avatar
Car: 1991 z28
Engine: 5.7 tpi
Transmission: th700r4
I'm with vetteoz, those boots worked great for me as well. randy
Old Mar 24, 2010 | 11:50 PM
norcalz28's Avatar
Ordered up a set. Thanks guys
Old Mar 24, 2010 | 11:59 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
I've been using a similar boot since '03 with my uncoated headers and have yet to have a problem with my 8.5mm wires
You'll be happy
FYI, there's a C-clip inside one end of the boots....pry it open a bit with pliers to make slipping them over your boots easy and squish 'em shut some after...they go up the wire, away from the plugs
Some pics for ya...Post #26
https://www.thirdgen.org/forums/exha...ader-help.html
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
