What engine wire loom / cover to use for TPI wiring?
Old Mar 28, 2010 | 11:11 AM
dave w's Avatar
I'm installing a TPI system into a Classic Chevy. I plan to run the TPI wiring inside the runners / below the upper plenum. Is there a wire loom, other than the factory black split loom, to tuck the TPI wires into?
I'm open to suggestions
dave w
Attached Thumbnails What engine wire loom / cover to use for TPI wiring?-0729081618a.jpg
Old Jan 1, 2013 | 12:54 AM
rockin the z's Avatar
Car: 1985 IROC Z
Engine: 305 F/I
Transmission: auto
Re: What engine wire loom / cover to use for TPI wiring?
which set of wires?
Old Jan 1, 2013 | 06:40 PM
dave w's Avatar
The pics below are what I was wanting to use splt loom on.
I ended up using a nylon split loom from:
http://www.wiringproducts.com/conten...wire_loom.html
dave w
Old Jan 1, 2013 | 06:45 PM
malcom2073's Avatar
Car: 1987 IROC-Z
Engine: 383ci SBC
I get mine from waytek wire:
http://www.waytekwire.com/products/1...rrugated-Loom/
A bit lower temp rating, only 125C, but super cheap and really easy to work with, not too stiff.
Old Jan 1, 2013 | 08:02 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I'd just buy some split loom & make it to fit how YOU want YOUR car to look vs having to rely on somebody elses idea of how your cars wires should look.
Old Jan 3, 2013 | 09:46 PM
dave w's Avatar
Point taken, which is exactly what I did. I was looking for a wiring product, not how to wire up the car.
dave w
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
