85 tpi high idle when warm
Old Mar 28, 2010 | 12:36 PM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
my brother picked up an 85 iroc 305 tpi, the car idles, starts fine when starting the first time in the morning(cold start) starts fine after the car has been running for a little bit(hot start) i check vaccum lines, replaced 2 that needed it, didnt help, tested the throttle position sensor, that checks out, i also did the spray carb cleaner around everything that could leak, that also checked out, i also cleaned the the throttle body, it was hella dirty. now after reading through 50 or more old posts from last night and this morning, cause yes i love using the search function, lol..... my last thing is gotta be the map sensor.
please let me know what you think, is there anything else i should check ?
thanks for the help
Old Mar 28, 2010 | 04:58 PM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
Re: 85 tpi high idle when warm
ok im getting code 22 any ideas
Old Mar 28, 2010 | 07:04 PM
bcmag's Avatar
22 indicates idle control malfunction.check iac valve and make sure min. air rate properly set.
Old Mar 28, 2010 | 09:40 PM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
i pulled the aic, cleaned and reinstalled, idle is now somewhat back towards normal.
thanks bcmag
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
