Hot Start Issue
Old Mar 28, 2010 | 09:15 PM
campbellerman's Avatar
Car: 1990 Trans Am
Engine: 305 TPI L98 cam
Axle/Gears: 3.42 eaton
Hot Start Issue
i am having this problem with my car. i recently replaced the pickup coil and cleaned my distributor and replaced the module but this problem started BEFORE i did this so i don't believe it is anything that i have done ok here's what my car does: engine at operating temp, i can turn off the engine and then try to start it again but engine only cranks and does not start. i have perfect spark when this happens. the car has new injectors and 45 psi at the rail and 35 while cranking EGR valve is still attached but is disconnected, engine timing is set to 6" degrees and i have no codes except EGR 32 and all the sensor data is in spec when checking with a scan tool. I am going to do some checks tomorrow to see what i can find. ANY input will be greatly appreciated!!
Old Mar 28, 2010 | 09:51 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Re: Hot Start Issue
Mine did that a few years ago and it drove me nuts trying to figure it out. I finally narrowed it down to 2 things. One being the coil. I went through 2 MSD stock replacement coils. I found they are junk, but was told by the owner of a speed shop near me that the MSD after market high performance coil is a good coil, and recommended it for my stroker engine so I got that. I also made a better heat shield for the starter/solenoid and wraped the starter/solenoid wiring in thermo wrap I also had the starter/solenoid rebuilt with better parts. Last summer was a good test, as it started every time, even after being heat soaked from driving.
Old Mar 28, 2010 | 10:13 PM
Car: 1990 Trans Am
Re: Hot Start Issue
i have a msd coil also i forgot to add that OOPS!! i tried the good stock coil and it still did the same thing
Old Mar 28, 2010 | 10:20 PM
Car: 1988 IROC-Z28
Re: Hot Start Issue
I kept my stock coil so when I was having starting problems originally I put the old one back on and problem solved. Then about 6 months later same thing again. Put the stock coil on and it started right up. Thats when I started looking into different coils. The MSD coil I use now is #8226.
Old Mar 28, 2010 | 10:26 PM
Car: 1990 Trans Am
Re: Hot Start Issue
ok but wouldn't the coil dieing cause no spark? jw i have good spark when it won't start
Old Mar 28, 2010 | 10:31 PM
Car: 1988 IROC-Z28
Re: Hot Start Issue
That was the strange thing. I put my timing light on it using it to check for spark. It would show a weak flash or intermittent flash. Then if I let it sit for awhile it would be ok?
Old Mar 28, 2010 | 10:40 PM
Car: 1990 Trans Am
Re: Hot Start Issue
i can turn the switch off and let it sit for a minute or two and it will start up
Old Mar 28, 2010 | 10:52 PM
LS7Roc's Avatar
Car: 88Roc Flame Red Black/Gold Pkg
Re: Hot Start Issue
Did you replace the ignition coil or the pickup coil in your distributor?
Old Mar 28, 2010 | 10:54 PM
Car: 1990 Trans Am
Re: Hot Start Issue
both it has a msd coil and a new pickup coil
Old Mar 28, 2010 | 10:58 PM
LS7Roc's Avatar
Re: Hot Start Issue
So it just cranks and cranks? If you wait a minute or two, it fires up?
Old Mar 28, 2010 | 10:59 PM
Car: 1990 Trans Am
Re: Hot Start Issue
yeah cranks and cranks and has a nice blue spark the whole time
Old Mar 28, 2010 | 11:03 PM
LS7Roc's Avatar
Re: Hot Start Issue
Does it eventually start?
Old Mar 28, 2010 | 11:04 PM
Car: 1990 Trans Am
Re: Hot Start Issue
it will after i let it sit for a minute or two
Old Mar 28, 2010 | 11:07 PM
LS7Roc's Avatar
Re: Hot Start Issue
Hows the fuel pressure when it doesn't fire up?
Old Mar 28, 2010 | 11:10 PM
Car: 1990 Trans Am
Re: Hot Start Issue
45 psi at the rail and 35 to 40 while cranking
Old Mar 28, 2010 | 11:16 PM
LS7Roc's Avatar
Re: Hot Start Issue
I had a hard start when hot issue...I replaced the pickup coil and it hasn't done it since. I use to have to crank it but it would start eventually. Because you tell me that it starts after two minutes, I'm thinking that if you crank it long enough, it should start..
Old Mar 28, 2010 | 11:19 PM
Car: 1990 Trans Am
Re: Hot Start Issue
i can start it up, drive it til its operating temp, turn it off, and try to start it again and it just cranks and it doesn't start. however if i let it sit for a minute it will fire right up. i checked for spark when it wont start and it has good spark
Old Mar 28, 2010 | 11:21 PM
LS7Roc's Avatar
Re: Hot Start Issue
Sorry bud, out of ideas...mind boggling that it will fire up after two minutes...
Old Mar 28, 2010 | 11:25 PM
Car: 1990 Trans Am
Re: Hot Start Issue
tomorrow i am going to put a noid light on the injectors and see if it flashes i know that air is a gimme, and if spark is present, then it has to be fuel issue thanks for all your help both of you!! if you guys think of anything else please post up!!!
Old Mar 28, 2010 | 11:37 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Hot Start Issue
check your spark plugs, ... on these engines if the first cylinder ignites, the rest fire up, right?
Old Mar 28, 2010 | 11:41 PM
Car: 1990 Trans Am
Re: Hot Start Issue
i had one out cause i have a misfire and it was fine i have autolite pp im planning on changing to delco's soon
Old Mar 29, 2010 | 12:19 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: Hot Start Issue
you double check your firing order? 18436572
Old Mar 31, 2010 | 06:54 PM
Car: 1990 Trans Am
Re: Hot Start Issue
i replaced the plugs with delcos and the misfire went away but it stiil wont start hot. i am out of ideas does anybody know of anything else to check? please heklp
Old Mar 31, 2010 | 10:00 PM
91chevyz28's Avatar
Car: 1991 Camaro Z28
Transmission: 5 speed
Axle/Gears: alunimum drum limited slip 3.08
Re: Hot Start Issue
I know you wrote you installed new injectors, but you should do an ohm test on the injectors while they are cold and after it gets to operating temp. to see if the ohms drop. It's just an idea since you tried a bunch of other things. I believe it should be at 16 ohms.
Old Mar 31, 2010 | 10:21 PM
Car: 1990 Trans Am
Re: Hot Start Issue
i did this today because i am starting to get desperate. when car is cold it starts right up and runs great. when it gets to operating temp and i shut it off and try to restart it, nothing happens. it just cranks and cranks and i do have spark, so it has to be no fuel. i will check the injectors again tomorrow thank you for the help
Old Apr 1, 2010 | 09:48 PM
Car: 1990 Trans Am
Re: Hot Start Issue
I figured it out guys!! i called up the local mechanic that my family has gone to for years, and i told him everything that i had replaced and checked. He said that he was 99% positive that it was the pickup coil that was bad. well i went down to oreillys and got another coil and installed it. car started right up and i let it warm up and i then shut it off. car fired right up first time!! i am so happy right now!! my mchanic mike campbell is a GENIUS!
Old Apr 5, 2010 | 10:16 AM
glentaybow's Avatar
Car: '89 Camaro LS
Engine: 5.0 L TBI
Re: Hot Start Issue
Hey guys....I'm having a similar hot start issue, but with a little difference: After the care gets hot and sits a few mins....it will initially fire, but just a few seconds, then shuts down. If you let it sit for a while, it then will start normally just like when it's cold. Could this be the pickup coil also?
Old Apr 5, 2010 | 09:08 PM
Car: 1990 Trans Am
Re: Hot Start Issue
it could be the pickup, it could also be the module is getting hot and cooling off: it could possibly even be your fuel pressure. Have you had you fuel pressure checked recently? Has the car had a tune up?
Old Apr 5, 2010 | 09:32 PM
glentaybow's Avatar
Car: '89 Camaro LS
Engine: 5.0 L TBI
Re: Hot Start Issue
I have not had a recent tune-up. Nor have I checked the fuel pressure. This problem has existed for a long time, but due to it's intermittent nature, the dealer where we take the car has been unable to resolve it. Fuel pressure regulator and fuel pump relay was replaced 4 years ago. Others have told me it could be a pressure problem. Thanks for answering.
Old Apr 5, 2010 | 09:55 PM
Car: 1990 Trans Am
Re: Hot Start Issue
your welcome my car did the same thing when my injectors were bad my car is tuned port but tbi would have the same symptoms if the injectors were bad my car would run normal cold but when the injectors warmed out they shorted out and the car ran like s***, replaced the injectors and fixed the problem
Old Apr 5, 2010 | 10:10 PM
glentaybow's Avatar
Car: '89 Camaro LS
Engine: 5.0 L TBI
Re: Hot Start Issue
Great! Gives me some things to look at. Thank you.
Old Apr 5, 2010 | 10:17 PM
Car: 1990 Trans Am
Re: Hot Start Issue
anytime i hope you figure it out if you will let me know how things check out
Old Apr 5, 2010 | 10:22 PM
glentaybow's Avatar
Car: '89 Camaro LS
Engine: 5.0 L TBI
Re: Hot Start Issue
will do, campbellerman! Thanks again.
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 26, 2015 04:59 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
