350 crate motor would this work
Old Apr 4, 2010 | 10:18 AM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
i have a stock 305 with under 90k miles, leaks some oil, but im looking for that 350 swap.
would something http://www.summitracing.com/parts/NAL-12499529/ like this work? Im planning on keeping my TPI to keep the cost down.
im trying to get an idea, and do some homework...been reading alot of post and using the search button, now it time for some feed back and ideas from fellow 3rd gen owners
thanks much for help
Old Apr 4, 2010 | 12:23 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
Re: 350 crate motor would this work
I can't see why it wouldn't work. You won't have to redrill your intake sine you are running an 86. Since you are running an auto the 2 piece rear main seal will work. I would look at the cam specs because you will need a custom chip of some sort. The lobe seperation may make tuning a bit of a challenge. I didn't see that spec. You will need some 24# inectors. Otherwise It looks like it would work. If you want the most out of it you really need to imporve the flow through your TPI. Good luck.
Old Apr 4, 2010 | 12:32 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
well, i dont know if you read the application list on summit but it says that its ment to be carburated and you are trying to have it TPI
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
thanks for the info and input, guess im gonna keep my eye open for a wrecked camaro with a 350 in it or pick up a rebuild
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
st.evel07
Aug 13, 2015 06:15 PM
