Scratching my head again...
Old Apr 4, 2010 | 11:30 AM
rrwebster's Avatar
Car: 88 GTA
Transmission: 700 R4
Axle/Gears: stock
So I've got a 305 TPI, it was not running real well, had flat spot around 1500-2000 almost sounds like its not running on all the cylinders... so I did a search, found some advise to do a tune up.
So I put new plugs, wires, rotor, cap and coil in. fired it up and it ran great, took it for a little ride... 5-6 miles, still had a slight hesitation around 2000rpm but that was very slight and it was running wonderfully. went back home and parked it.
Next day... it's back... almost running exactly the same as it did before I tuned it up.
50 degrees in the morning and it takes 5 to 6 trys just to get it to stay running.
It's just like everything I did before was undone.
Thanks in advance....
Robert
Old Apr 5, 2010 | 01:00 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Scratching my head again...
pull the trouble codes. Jump A & B in the ADLD port and note the codes so that we can narrow this problem down..
Old Apr 5, 2010 | 05:14 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
If theres one thing about thirdgens that I double check, it's plug wires, make sure the boot is tight to the spark plug.. Happens to me all the time..
Old Apr 5, 2010 | 06:24 AM
rrwebster's Avatar
Car: 88 GTA
Axle/Gears: stock
No codes to pull... just double check ed them.
Old Apr 5, 2010 | 06:25 AM
rrwebster's Avatar
Car: 88 GTA
Axle/Gears: stock
well that's a real simple check... I did make sure the cap had them all on real well... will double check the plugs too.
Old Apr 5, 2010 | 06:38 AM
rrwebster's Avatar
Car: 88 GTA
Axle/Gears: stock
Could this flat spot have anything to do with the TPS?
Old Apr 5, 2010 | 07:15 AM
rrwebster's Avatar
Car: 88 GTA
Axle/Gears: stock
plug wires are fine.
with it idling, if i give it a little throttle, sitting still it sputters, flutters, pops a little then I get some rpms...
Old Apr 5, 2010 | 09:05 AM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
Could it be a fuel problem? I would put a gauge on it at the rail and check your tps voltage just to rule those two things out.
Old Apr 5, 2010 | 09:19 AM
Did you tune up the TPI system?
http://74.125.155.132/search?q=cache...&ct=clnk&gl=us
http://mpikas.blogspot.com/2008/08/t...june-2000.html
Old Apr 5, 2010 | 09:29 AM
rrwebster's Avatar
Car: 88 GTA
Axle/Gears: stock
Originally Posted by Chevy86 IROC-Z
yes I did, it helped a little but still the flat spot problem, with sputter and slight backfire.
Old Apr 5, 2010 | 12:31 PM
rrwebster's Avatar
Car: 88 GTA
Axle/Gears: stock
brand new fuel pump and filter, sending unit and screen.
Old Apr 5, 2010 | 12:57 PM
Car: 1988 GTA
Do you get a smooth voltage increase from your tps as you open the throttle? TPS still sounds suspicious to me with the "flat spot" you're describing.
Old Apr 5, 2010 | 03:20 PM
rrwebster's Avatar
Car: 88 GTA
Axle/Gears: stock
Just got back from a new friends house... he been dealing with TPI and LT1's for years... He manually adjusted the TPS and found a vacumn leak in the hose that goes from the mainfold to the fuel pressure regualtor. That pretty much eliminated the flat spot. He had hooked his fuel pressure gage up when I first got there and saw the pressure was fine... about 10-15 minutes later the engine running that whole time it finally did what it's been doing... peeked at the fuel pressure gauge and it had dropped to 20 LBS and the engine was about to die. This is with a brand new fuel pump. turned the key off and waited a little bit; it start right back up and ran fine for a couple of minutes and did the same thing... so It's been a new faulty fuel pump all along.
One question; thought I've had. when I replaced the fuel sending unit, I put the 1 week old pump on the new sending unit. my kit came with a hose long enough to bypass the pulsator. I didn't do that, I used the old pulsator. Should I have tossed that and just used the rubber hose?
Ordering a new fuel pump today...
Old Apr 5, 2010 | 04:15 PM
I would of replaced with the new rubber hose due to the fact that you may run into future problems. But now that you have to drop the tank agian, I would do the switch. Better now than later now that the tank will be down.
Old Apr 6, 2010 | 06:43 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
I would put a new pulsator valve on it, it does serve a purpose plus they're cheap enough.
Jake_92RS
Jan 28, 2020 10:37 PM
deracer
Apr 11, 2016 12:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
