Fuel troubles after new ecm
Old Apr 7, 2010 | 04:14 PM
blue_thunder91's Avatar
Car: 1991 Camaro Z28
I installed my new ecm about a week ago and have driven the car about 24 miles on new ecm. This morning car would crank but wouldn't turn over, so I sprayed some starting fluid and after a bit cranked right up. So I figured fuel pump failing, right? Fuel pressure is fine and car worked great until about 20 minutes of driving car just died and would crank but no start unless using starting fluid. Changed fuel filter and was going to change pump but then car cranked right up, then happened again after a while. Any ideas, should I just replace fuel pump eventhough it seems to be working
Old Apr 7, 2010 | 04:31 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: Fuel troubles after new ecm
same thing was happening to me and it turned out to be the fuel pump
Old Apr 9, 2010 | 12:01 AM
i changed the fuel pump and now idles high....new iac installed also I am stumped. TPS signal good also not sure where to begin now.
bryan623
Mar 22, 2021 06:43 PM
stalkier
Dec 6, 2015 11:25 PM
Jae992
Aug 27, 2015 09:07 AM
djmarch
Aug 19, 2015 12:07 PM
