stock valve covers with 1.6 rockers and AFR heads
Old Apr 9, 2010 | 08:12 PM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
is it possible?
Old Apr 9, 2010 | 09:17 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: stock valve covers with 1.6 rockers and AFR heads
I wonder also
Old Apr 9, 2010 | 11:00 PM
redcorvette's Avatar
Car: 85 vette
Engine: 427 SHP block,AFR 210,MiniRam
Transmission: TKO 600
Axle/Gears: 3:07
I am running AFR 210's with stock valve covers and 1.6 rockers. I had to remove the oil drippers inside the covers because of the extra width of the rockers. When I was running stock 624 iron heads I had to use two valve cover gaskets on top of each other to get enough height to clear the rockers.
Old Apr 9, 2010 | 11:42 PM
Engine: L98 and L03
so is it possible that the narrow body rockers would work without modification? not too worried just curious, also what kind of lift are you seeing?
Old Apr 10, 2010 | 02:52 PM
Car: 85 vette
Axle/Gears: 3:07
I am running about .580 lift with 1.6 rockers (XFI 280 cam). I am not sure what will work without modification, I think (it's been a few years) I just used a set of vice-grips and bent the drippers back and forth until they came out. At the time I was using Crane Energizer rockers that are pretty wide and there was no way of putting the stock valve covers on the stock 624 heads without doing something. For vette owners you are limited in valve cover height because the windshield washer motor is in the way. To use tall valve covers you have to notch the back corner of the cover.Thats why I stay with stock covers. The AFR 210's seen to have a taller lip that allows me to use 1 gasket.
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
Street Lethal
Aug 12, 2015 11:33 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
mustangman65_79
Aug 8, 2015 01:18 AM
