Question about modifcations from 305 to 383
Old Apr 10, 2010 | 11:40 PM
carlh's Avatar
I have an 88 firebird formula with a 305 tpi that I want to pull out and put a 383 stroker in. I was wondering if anyone knows what modifications need to be made to the tpi. I have heard that I have to board out the runners and intake. I would not like to spend more than $5,000 on it. Does anyone know what the best kind of motor is to put in it? Please let me know if anyone has any suggestions. you can also email me at carlh2498@gmail.com.
Old Apr 11, 2010 | 12:06 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: Question about modifcations from 305 to 383
you will need to tell us more info about the 383?? RPM range, Cam,Compression,cc, valves, Gears
do you have headers ? and exhaust ? high flow cat ?
first you will need 22-24 # injectors
I would get a 52- 58 mm TB
you will need your eprom flashed to a 350 and then tuned for a 383.. and other mods
for the amount of work you will need to mod the TPI set up
I would convert to a HSR or similar if emissions is needed
84z96L31vortec
Aug 20, 2017 12:16 AM
mhatfield 14
Oct 24, 2015 07:48 AM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
