coolant smell
Old Apr 15, 2010 | 07:12 PM
thegoochking's Avatar
coolant smell
i have been getting random wiffs of burning coolant while driving more when accelerating fast but cant find any coolant leeking anywhere. I can smell it from inside the car and when i get out i can smell it alittle. I had a hose spring a hole last week and spray the **** all over the inside of the engine bay but i replaced the hose and it just started with the smell along with the smell comming from her running realy rich which i have to pinpoint that problem now also.
Old Apr 16, 2010 | 04:31 AM
likeyoumeanit's Avatar
Car: 87 GTA
Transmission: soon to be t56
Axle/Gears: 3.73 posi
Re: coolant smell
heater core maybe?
Old Apr 16, 2010 | 04:55 PM
Re: coolant smell
could the heater core have anything to do with me not having a belt connected to my ac compressor? it seemed to have started after that was removed.
Old Apr 16, 2010 | 07:05 PM
Re: coolant smell
found the promblem it is the heater core, coolant all over the passenger carpet. How do i fix this dam thing haha
Old Apr 16, 2010 | 09:25 PM
Re: coolant smell
can i do something to bypass it so its not in use? i dont need heat its like 90 degrees every day here in florida. Id rather make it not usable anymore
Old Apr 24, 2010 | 12:39 AM
severedsanity's Avatar
Re: coolant smell
Pull the 2 hoses off under the hood going into the firewall on the passenger side. You need to get a brass fitting so you can connect the 2 hoses together, thats it, heater core is out of the loop. I cant remember what size fitting it is that you need? The hoses are like a half inch or less in diameter.
Old Apr 25, 2010 | 12:26 PM
Re: coolant smell
connectors are gone and now so is the coolant smell. Now the only smell that is bothering me is the smell of gas from a rich tpi. I think it might be the o2 sensor but i have no idea where it is hooked up to replace it. Can anyone tell me where to find it? Car spit out white gas smelling smoke on start up and idles high for a while usualy arround 1200 to 2000 then calms down after a while to 6 or 700. Also smells like gas when i punch it while im already going arround 50
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
