ARGH!!!!!!!!!! SLP runners.
Old Apr 15, 2010 | 08:57 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
ok, so i am trying to remove the whole intake manifold setup...
i had to order the SLP tool for the allen head bolts for the runners...which works GREAT!
except...
2 of the bolts are completely stripped, the allen doesnt even try to bite, using my camera to see the bolt head, its completely rounded!!
they are BOTH in the worst possible spots...first one is on the drivers side middle lower between cyl 1-3...the second is on the pass side lower, between 6-8...
how in the HELL am i going to get these out, ive spent the last few hours trying to find a way to do it without hurting the runners, or the base{its a scoggin dickey lower}
any ideas/thoughts/suggestions?
Old Apr 15, 2010 | 09:03 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
re: ARGH!!!!!!!!!! SLP runners.
except...
if you have access to a cutoff wheel you should be able to fit it with a new 5" disk make a grove deep enough but not all the way through after you do this you sound be able to fit a flat head bit or a flat screwdriver to get it off (i recommend the flat bit and a screw gun)
just get the wires out of the way
Old Apr 15, 2010 | 09:05 PM
On Probation
if the stripped ones were on top, this would be easy...
mine are on the bottom, in the middle...the runner completely covers the bolt...
only thing i can think of to try is to use a small drill bit, and one of those reverse thread extractors...drivers side one shouldnt be much issue....the passenger rear by the hvac box is going to be next to impossible i think...
Old Apr 15, 2010 | 09:11 PM
juanillox8's Avatar
Car: TOO MANY
ok i just went outside to check on mine... it seems that you might have to take the valve cover off
Old Apr 15, 2010 | 09:18 PM
On Probation
i have both vc's removed,theres just no way to get a grinding wheel in there without completely destroying the runners/lower intake.
Old Apr 15, 2010 | 09:26 PM
juanillox8's Avatar
Car: TOO MANY
how about a dremel? it uses a much smaller disk 1"
Old Apr 15, 2010 | 09:27 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
lol good luck man try and keep them in one piece for me.
Old Apr 15, 2010 | 09:32 PM
On Probation
haha thanks, this sucks man. ill prolly end up pulling the A/C box on the firewall to get more room....looks like ill be swapping to my non a/c box sooner then expected HAH!
Old Apr 15, 2010 | 09:40 PM
JERRYWHO's Avatar
how in the HELL am i going to get these out any ideas/thoughts/suggestions?
Very ez to get them out.
http://www.toolprice.com/c=CppG6xQGs...t-Removal.html
Just hit any hardware store and if the ez out bottoms out before it grips then just grind off the end of the ez out to get the right fit in your round hole.
Jerry
Old Apr 16, 2010 | 01:03 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
for removing damaged allen head bolts i prefer using one of these if i have the right size,
http://www.usatoolmart.com/HandTools..._25_Piece.html
in a pinch i have also used a torx socket a few times to remove damaged allen bolts by driving the torx bit into the allen bolt head.
Old Apr 16, 2010 | 08:36 AM
juanillox8's Avatar
Car: TOO MANY
he's calling them allen but many people mistaken torx for allen, if he has the og bolt they will be torx and he said they are completely stipped i stil would use a dremel i checked on mine and the dremel disk fits
Old Apr 16, 2010 | 08:57 AM
On Probation
i have SLP runners...i know very well what a torx bit, and what an allen look like..
i indeed have ALLEN head bolts.
what you are not understanding is, there is ZERO room to get a dremel/grinding wheel in to notch/cut off the head..
Old Apr 16, 2010 | 01:43 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
just drill the head of the bolt off....remove the runner....then use vicegrips to remove the stud. did this on a tork that stripped...
Old Apr 16, 2010 | 04:27 PM
profootbrake2's Avatar
Car: 92 Camaro Z28
Engine: ZZ4 TPI
You could try a long 1/4 allen and hammer it on to the bolt to get some grip. This is only .013 bigger
Old Apr 18, 2010 | 11:17 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Hammer a cheap socker over top of the , im guessing round, allen head bolt. I had SLP's, in stock form they really aren't much of an improvement over OE runners, and the rough casting IMO is not worth the money. Bought a pair of chunky ACCEL runners, ported the hell out of them, and there is no comparison.
Old Apr 21, 2010 | 05:18 PM
Kolby's Avatar
Car: 1988 Trans Am GTA
Engine: 350 5.7
Re: ARGH!!!!!!!!!! SLP runners.
I used an easy out.
Old Apr 24, 2010 | 06:56 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
The best thing I used was a set of easy outs made by craftsman. Just check em in a drill and start drilling in reverse. Once you get deep enough the bit will grab the bolt and out it goes.
Old Apr 24, 2010 | 08:04 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I've used this same method. The stripped opening in the head of the bolt makes for a great pilot hole to center the drill bit. Just work slowly and once the head is gone, the runner should come right off. Also, in my case, once the runner was off I was able to remove the remaining bit of bolt with my fingers.
Old Apr 25, 2010 | 08:17 AM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Try one of these sets of bolt removers, I know both Lowes and O'reilly carry them, lots of others too.
http://www.irwin.com/tools/browse/sc...olt-extractors
I have them in my toolbox at the shop and they've worked great for me many times.
Old Apr 27, 2010 | 03:09 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
just find an allen key/socket that is slightly too big, and lightly grind each face on an angle so that the hex tapers down to fit inside the bolt. then hammer that into the bolt the best you can. the taper will wedge the key/socket into the bolt, and the hammering will loosen the bolt, hopefully enough that it will unscrew. If these are the last bolts you have left, put some back in and torque them down so that the bolts have less stress on them. in the future, as a tip, especially with torx/allen bolts, give them a few whacks with a hammer with the socket installed, it helps to loosen them up. very very critical with the torx bolts holding the accessory brackets onto the front of the engine.
Old May 8, 2010 | 02:53 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
whats the deal? no package yet
Old May 10, 2010 | 11:05 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Small pair of needle-nose vice grips...
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
