90 engine, 89 ecm/prom in '88
Old Apr 27, 2010 | 08:17 AM
Happy Fun Me's Avatar
Engine: T.P.I. 350
Transmission: 700r4 Auto
I have an '88 iroc I just got not long ago, but I also have a '90 engine with cut harness and '89 ecm and prom. I was just wondering if swapping in these things would provide much improvement and what other modifications would be necessary.
Old Apr 27, 2010 | 02:18 PM
X-Ravin's Avatar
Car: 91 Camaro RS
Engine: Freshly rebuilt 350 with goodies.
Transmission: 700R4 w/ 2000 Stall
Re: 90 engine, 89 ecm/prom in '88
Unless the '90 engine has a lot lower miles than your current engine I don't see much of a point. The only real difference between the 2 is that the 88 is a MAF system and the 90 is a MAP system. From what I understand MAP is harder to adapt to mods. Because of that difference you need a '90 PROM, anything older will not be compatible. I'm no expert though, so hopefully more will chime in. You may have trouble dropping the 89 PROM in the 87 because of VATS.
Old Apr 27, 2010 | 02:31 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The 90 engine can work just fine being controlled by an 88-89 ECM, so long as you swap the necessary parts over. In this case, that would be the mass airflow sensor, and removal of the MAP sensor.
Since neither the 89 nor 90 use the 9th cold start injector, the ECM & PROM should have no problems with the 90 motor as long as you use the 89 MAF.
Old Apr 28, 2010 | 09:11 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
If your 88 doesn't have vats that might present a problem, you may need a custom chip with the vats deleted, or you could use the chip from the 88.
other than that the motor should run fine with the 89 maf setup.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
