sensors on 91 Z/28's
Car: 1991 red Z/28
Transmission: T5 swap
What are all the sensors on 91 Z/28's? I know I have to get a MAP sensor because there isnt one there. Probably an EGR valve and an EGR vacuum soleniod (not sure if the 85-88's are the same). I just want to make sure I have all right sensors for my car because some might be missing.
Car: 1991 red Z/28
Re: sensors on 91 Z/28's
Here is a list I came up with. I think that covers most, if not all of them.
I put on everything that has an electrical connector to it.
Knock Sensor
Map Sensor
Throttle Position Sensor (TPS)
Oxygen Sensor
Coolant Temperature Sensor (CTS)
Intake Air Temperature Sensor (IAT)
Idle Air Control Valve (IAC)
Vehicle Speed Sensor (VSS)
Oil Pressure Sender
Coolant Gauge Sender
Egr Solenoid
Knock Sensor
Map Sensor
Oxygen Sensor
Oil Pressure Sender
Egr Solenoid
Car: 1991 red Z/28
Knock Sensor
Map Sensor
Oxygen Sensor
Oil Pressure Sender
Egr Solenoid
Knock Sensor
Map Sensor
Oxygen Sensor
Oil Pressure Sender
Egr Solenoid
Thanks for the list. It will be a big help when I start putting my engine and harness together. Thread
HoosierinWA
Oct 7, 2015 10:15 AM
