Trans Am V8 TPI converted to Edelbrock Carb won't start
Old May 1, 2010 | 07:28 AM
SpaniardV6's Avatar
Hello,
I bought last March a Trans Am V8 original TPI, but the first owner convert it to carb using Edelbrock Carb.
Last week, the engine won't start. I check the coil wires,its ok, check the coil, is bad.
I bought 2 new coils, but replace the bad coil using one of this, and the car won't start. I put the other new coil, but the car make the same, won't start.
There is fuel into fuel filter (the fuel filter is around the Carb), have fuel, have new coil, but won't start.
Any ideas?
Old May 1, 2010 | 08:06 AM
SpaniardV6's Avatar
Re: Trans Am V8 TPI converted to Edelbrock Carb won't start
I'm looking the coil voltage... and into the two wires come from wires package to the coil, (pink and blank), have positive and... positive .
Must be + and -, isn't it?
Old May 1, 2010 | 09:52 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
check fuel pressure to the carb. is it a mechanical fuel pump or the "in tank" pump. what kind of distributor is it?
Old Jan 11, 2011 | 01:54 AM
SpaniardV6's Avatar
The cause was bad wires to the coil . Sorry but I don't remember of close the post. Thanks!
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
FormulasOnly
Jul 23, 2018 08:47 AM
cheesehomer
Dec 31, 2015 08:48 AM
bjpotter
Oct 4, 2015 07:48 PM
