Freeze/Expansion Plug gone bad?
Old May 9, 2010 | 07:17 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
at the last F-Body Empire meeting Captain_Camaro pointed out that i was leaking coolant...
my coolant has been disappearing from the res so this explains it..
when i first got my car 3 years ago, it had a blown freeze plug.
questions:
1. How many freeze plugs are there?
2. Where are they?
3. Where can i get them?
Mikey
Old May 9, 2010 | 08:38 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Freeze/Expansion Plug gone bad?
Eight
2. Where are they?
In the front , sides ( two behind engine mounts ) and the back behind flywheel .Plan on pulling the engine or trans
Any auto parts shop; std SBC plugs
Old May 10, 2010 | 02:07 AM
Guest
Guest
Posts: n/a
I'd locate where exactly the leak is coming from first, should be easy enough to find.
Old May 10, 2010 | 11:04 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
yea...when i got out of my bird at school this morning there was a puddle of coolant
ill have to check when i get home
Old May 14, 2010 | 12:41 AM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
word of advice never use one of the expanding rubber ones.....I used one to do a quick fix when my block heater started leaking long story short about a week later nailed it from a stop right and it shot out of there, and lost all my coolant in a matter of seconds
Old May 14, 2010 | 12:08 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
ouch...alright...so the brass ones??
Old May 14, 2010 | 12:10 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
anyone have a link to them??
Old May 14, 2010 | 12:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
They're super common - just search for freeze plugs.
Buy a kit for $8 or whatever, and some RTV (or preferably gorilla snot - ie 3m weatherstrip adhesive) and replace the one(s) that are leaking.
Enjoy - they are not easy to get to while the engine is in the car.
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
