Fuel issue
Old May 13, 2010 | 12:39 PM
menace156's Avatar
Fuel issue
I have an 85 TA. Sweet car if only it would run. It is a 305 tpi all stock. Replaced the fuel pump and starter. Can get the car to almost crank over, but it wont. the only way to get it to crank over and run is with starter fluid....wont stay running otherwise. any ideas? need the help desperately.
Old May 13, 2010 | 12:45 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Fuel issue
at the fuel injectors, while cranking check to see if there is a pulse ... also check to see if there is spark... could be a faulty ignition module.. they are notorious to go out all of a sudden...
Old May 13, 2010 | 12:51 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: Fuel issue
Agreed, bad ignition module.
Old May 13, 2010 | 12:56 PM
menace156's Avatar
Re: Fuel issue
Well, i did a little digging through here and found in the next thread about a 86 Z that we are having the same exact problems. Idk what else to do except follow his lead, but if u guys can help its much appreciated.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
