Need some vacuum help
Old May 24, 2010 | 09:45 PM
X-Ravin's Avatar
Car: 91 Camaro RS
Engine: Freshly rebuilt 350 with goodies.
Transmission: 700R4 w/ 2000 Stall
Ok so I've been having lots of issues with my Camaro and I finally got some time to start digging around. I've found nearly the entire vacuum system is routed wrong. Some of it I know how it goes back together, but I need to know where the lower vacuum port on the passenger side of the TB goes, the one right under the CCV line. My car had a badly cracked and leaking plug on it.
Another question I have, would having things like the FPR and EGR connected to the wrong vacuum ports cause fueling and idle issues?
Old May 26, 2010 | 08:58 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Need some vacuum help
Is vac port for charcoal canister purge line
So long as they are seeing intake vac doesn't matter where vac it comes from
Old May 26, 2010 | 09:18 AM
X-Ravin's Avatar
Car: 91 Camaro RS
Thanks for the help, when I went back and looked at the diagram it made more sense. My FPR was plugged into the ported vacuum outlet on the bottom of the TB tho, which I think would cause some issue with idling. I almost have it replumbed and will know soon.
Old May 27, 2010 | 10:08 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
the egr valve is controlled by a vacuum solenoid that opens and closes the valve by commands of the ecm, putting a constant vac source on the egr may cause issues.
Old May 27, 2010 | 11:49 AM
X-Ravin's Avatar
Car: 91 Camaro RS
Well I think the EGR valve is stuck partially open. I can apply constant vacuum or no vacuum at idle and nothing changes.
Old May 27, 2010 | 10:44 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I assumed he had the EGR solenoid and lines in place and was asking about the vac source for it
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
