305 tpi running hard
Old May 27, 2010 | 05:28 PM
87irocz2887's Avatar
My 87 iroc 305 tpi is has trouble starting at times. It has alot of hesitation when you give in throttle and when its in neutral or park and you rev it up the engine wants to shut off when the rpms come back down. So far i have changed the fuel filter, plugs,wires, cap and rotor. The electric fans stay on constantly. I'm not sure if the coolant temp sensor could cause this or it might be the timing is off. any suggestions?
Old May 28, 2010 | 02:20 AM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
Re: 305 tpi running hard
when i was experiencing similar issues i found trouble with injectors. also do a search for IAC while you're at it
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
