Worst no start
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
Re: Worst no start
ok,with vaccum line off of fpr, it idles at 48 psi...put back on it idles at 40,41....drives fine either way,just needs starter fluid for crank on first try...........however, either way fuel pressure bleeds down to zero in 35 seconds when turned off..how far should pressure drop or should it hold...with 48 psi unplugged seems fuel pump is ok....so is this bad injector or fpr.........
92camaroJoe
Aug 13, 2015 06:07 AM
