quick question
Old May 28, 2010 | 12:45 PM
87TAGTA66's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: Stock 3.23's
quick question
ok im sure this isnt the right forum but i wasnt sure which one to go to. im trying to remove clutter from under the hood and want to remove all the AC stuff and was wondering what all i could remove/disconnect and allow the heater to still work in the winter.
Old May 30, 2010 | 08:43 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: quick question
You can remove all the A/c stuff and just leave the two heater hoses running to the heater
A/c delete was a option in some cars.They came with a different blower housing that did not have the evap core.You might find one in a junkyard if you want a cleaner look
Old May 30, 2010 | 02:54 PM
87TAGTA66's Avatar
Engine: 5.7 TPI
Re: quick question
Ok so I noticed there is a line running to the radiator. Can I just loosen that line and take it off or will it leak coolant?
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
