Time to start planning out motor upgrade.
Old May 27, 2010 | 06:01 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
OK folks, I'll list out what I want to go with and you fill in the gaps or slap me with a trout if I'm way off. The * indicates what I have now.
Vortec heads
1.6 RR
Cam???
Vortec TPI manifold ported to match the runners
AS&M Large tube runner*
Plenum ported to large tube runners*
52MM BBK TB*
24LB SVO inj*
BBK AFPR*
underdrive pullies*
Edelbrock TES headers*
3" catback to flowmaster 80*
150 shot NOx*???
I'm not looking for a drag strip monster, just something fun on the roads.
This is all going in an 87 TA with a 700r4 and Borg Warner 9 -bolt with 3.27s.
I can get the heads for $450, less if i can find some junkers to use as cores.
TPI intake for $500 with shipping or less if i can find used.
I'm hoping to keep everything under $1500.
I also have the equipment to burn a new prom, just not the know how to do it.
Old May 30, 2010 | 07:05 PM
schnydz's Avatar
Car: 90 Iroc
Engine: TPI 305
Axle/Gears: 3.73 LSD
Re: Time to start planning out motor upgrade.
Hi Dr, I just pickup up a used vortec 5.7 long block(free) in need of a rebuild and have recently been doing a lot of research. I've been looking at
https://www.thirdgen.org/forums/engi...st-builds.html scroll down to tpi350.
also http://sdparts.com/details/scoggin-d...nter/sd360vtpi look at the specs of the motor and the hp/tq numbers.
also http://www.camaroperformers.com/cama...all/index.html for more engine parts specs.
atilla's numbers are amazing. the other 2 are pretty good too.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
