EGR Related Testing
Old May 30, 2010 | 07:32 PM
xhozst's Avatar
Car: 85 iroc-z tpi 45k mi,,,77 1/2 z28
EGR Related Testing
So i know how to test the EGR valve and it is working just fine. I'm not getting any vac between the EGR Vaccuum Solenoid when warm and middle throttle. How do i determine if its the solenoid or the temp switch and how do i test each? Thanks,
Old May 30, 2010 | 11:32 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: EGR Related Testing
Temp switch test. Follow the picture to see if the switch is working. You want to wire in series. This test will veriefy if the little filament type metal bends with heat, causing it to ground itself. The proper term is a "continuety test." If you wire it up to the multimeter and automatically it presents a continuety load or grounding, then the switch is bad. It only grounds itself with heat. Then your next culprit would be the solenoid. I dont know how to test this one but if you suspect it is bad, you should change it out because it is directly connected to your ECM. According to the ECM sticker, it warns that if any solenoid is under 20 OHMS, it would damage the ECM.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
