Why does every TPI you see have dents?
Old May 28, 2010 | 04:17 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Just about every TPI setup I've seen for sale (including the one I ended up buying) has dents in some of the runners. Is there any specific reason for this, like changing some sensor or hose nearby that is hard to get to or something? I'm putting the runners and plenum on my engine tonight and just want to avoid any unnecessary denting!
Old May 28, 2010 | 04:48 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Re: Why does every TPI you see have dents?
Most of the setups prob sit in a box on a self somewere for a couple of years before people deside to sell them.
Old May 28, 2010 | 06:07 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
They're really, really easy to dent while taking off if you are not careful also. Most recyclers don't take pains removing them, and beat um up with ratchets and wrenches, and sometimes beat on them with hammers to break loose runners not knowing that there is a couple more bolts on inside under plenum.
Old May 28, 2010 | 09:28 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Yep, they're 20+ years old, super easy to dent, and it's getting more difficult to find pristine ones. Nitro
Old May 28, 2010 | 09:34 PM
BlwnSS's Avatar
Car: 1999 Formula Hardtop
Engine: 6.2 forged ls3 Procharged
Transmission: t56 Magnum
Axle/Gears: midwest chassis fab 9/3.50
ive seen ***** on ebay, either 4 or 5 steel ***** that you push through the tubes to straighten them out .
Old May 29, 2010 | 11:27 AM
brutalform's Avatar
Alot of times, while removing an engine, the hoist chain will dimple them if you are not careful.
Old May 29, 2010 | 01:31 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Plus they're ALUMINUM. Which is very soft. And yes back in the day when these cars were new i'm sure the GM techs didn't treat them too nicely, especially if they had to change intake gaskets they most likely got frustrated and started banging the runners to get them under the fuel rails and stuff.
3tas4me
Sep 4, 2015 01:45 PM
hepcat620
Exterior Parts Wanted
Aug 30, 2015 07:52 PM
Thaney9
Aug 29, 2015 03:16 PM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
