TPI removal.....
Old May 30, 2010 | 11:17 AM
kap's Avatar
kap
TPI removal.....
I'm in the process of taking the plenum and tubes off the intake. Plenum is off but tubes are stuburn. I removed all the bolts including the two under the plenum but the tubes wont break lose from the intake. Any ideas on how to break them loose without damaging them?
Old May 30, 2010 | 12:18 PM
85irocproject's Avatar
Re: TPI removal.....
have you taken off the inside bolts, there is one up front and one in the back underneth the fuel regulator
Old May 30, 2010 | 07:29 PM
kap's Avatar
kap
Yes I have had...they seemed to be stuck.
Old May 31, 2010 | 07:04 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
IF you have ALL the bolts out then tap runner flange gently with soft hammer.The gaskets bond to the parts locking everything in place without the bolts.
Old May 31, 2010 | 08:04 AM
heres a few pics to make sure you got them all out, should be 10 including the plenum.
File Type: jpg
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
