bad injectors?
Old Jun 1, 2010 | 02:20 PM
87irocz2887's Avatar
bad injectors?
I have a 87 iroc 305tpi. The car was running rough and had little power, would stall out in gear and at stop signs. I set the timing to 6 degrees and it helped a little but it is still lacking power. I want to test the injectors and make sure they are the problem before tearing it apart. so far Ive replaced plugs, wires,cap and rotor, and fuel filter. I had the car running and unplugged one injector at a time. when i unplug injector #3 and #6 there is no difference in idle. If i unplug the others one at a time theres a difference in idle. I also have a gas smell in the oil. Could this be the injectors?
Old Jun 3, 2010 | 08:00 AM
southbay08's Avatar
Re: bad injectors?
check ohm on the injectors, then pull the plugs, if you have a wet cylinder then you have a leaky injector
mike_c
Aug 27, 2015 04:32 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
Bryan F
Aug 18, 2015 02:28 PM
