Modify 87 TPI base for 84 heads?
Old Jun 13, 2010 | 08:47 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
I've talked my daughter into converting her 84 T/A to FI. I'm supposed to pick up a TPI system from an 87 IROC this weekend. Most sites say I need a non-roller block base (85, 86 F-body or aluminum head Corvette). I've seen some hints that the center mounting holes can be modified. What about the EGR passages? Which base gasket would I use?
Old Jun 14, 2010 | 08:14 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Modify 87 TPI base for 84 heads?
You just slot the the two center holes in the F-Body intake to suit the different bolt angle used on the regular SBC heads.Might need a washer under bolt head
Intake gasket is the same; only the angle of the center bolts differs .
72 degrees vs 90 degrees on pre '86 iron and Vette alum heads
Old Jun 15, 2010 | 06:17 AM
ACCLR8N's Avatar
Thanks, I should have checked Rock Auto to see same gasket used.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
Sanjay
Aug 12, 2015 03:41 PM
