code 34 and 36 diagnostics
Old Jun 16, 2010 | 05:46 PM
street_carnage's Avatar
Car: 89 GTA
Engine: 5.7L
So the car is stalling while driving and at startup occasionally. Fuel economy has gotten worse. Smells rich when trying to stall while driving. throwing code 34 and 36. got bad today when i could barely make it home but now its running fine again but the ses light is still on.
its pissing out rain so im not working on it tonight, but getting everything in order for when i do.
first i will actually inspect the maf for broken wires, damage etc. Note that i have a cold air intake which only fits with the maf unbolted from the mount so it could possibly be damaged right?
if the maf looks ok visually. i will replace the maf burn off and power relays, reset ecm and check. And i will check the TB and all hoses etc. for vacuum leaks. Oh, and what about the fuel pump relay...it usually primes...
Just to be sure i will check/adjust/clean TPS and iAC
Any other advice? im pretty new to TPI ive always had carbs in my third gens.
1 other thing, are napa etc. relays really that bad, should i really pay 2x more for gm relays?
thanks guys, i hope you can help. I need this fixed asap. i searched and just wanted to summarize that i got everything right.
Old Jun 17, 2010 | 12:14 PM
tpi81's Avatar
Car: 85 Camaro-81 Chevy
Engine: 350-350tpi thats right tpi n my trk
Transmission: none-700R4 for gas
Re: code 34 and 36 diagnostics
34 is MAP SENSOR VOLTAGE (LOW)
36 is ignition system circuit error
Mine has about the same readings mine is reading
33 and 36
Mine reads on my computer
33 which is a MAP SENSOR VOLTAGE (HIGH)
And it runs 36 just like yours!! LOL
I need some help with mine also so we're in the same bind!!
I think your Mass Air Flow sensor is fine
Old Jun 29, 2010 | 10:49 PM
Car: 89 GTA
Engine: 5.7L
ended up being relays
Old Aug 11, 2010 | 12:06 PM
asfalto's Avatar
Car: '88 camaro iroc-z
Transmission: TH 700 R4
Axle/Gears: 2.77 Borg Warner Axel
hi!
i get the same codes.. did you changed the fuel pump relay too?
thanks
Old Sep 10, 2024 | 05:25 PM
donjordahl's Avatar
Car: 89 IROC 68 SS Camaro
Man I’ve chased code 36 for so long without ever finding the root…
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
