High idle on lb9 5 speed
Old Jun 26, 2010 | 07:49 AM
Hutts's Avatar
Car: 1989 gta-1995 formula
Engine: 305 tpi
Transmission: 5 speed
Axle/Gears: 3-45
Wondering why my 89 gta takes a long time to come down to an idle when i pull up to a stop light or when i push the clutch to slow down or stop, it does come down to a good idle just takes a while, is this normal or do i have a problem thanks.
Old Jun 26, 2010 | 10:20 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: High idle on lb9 5 speed
mine sometimes takes about 2 seconds to idle down, but usually idles down right away when I slow down and press the clutch.
how long does yours take?
It could be a faulty IAC or TPS.
Old Jun 27, 2010 | 04:09 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
My car does the same thing. If I come to a stop real quick or sometimes even when im just stopping, the idle will jump up to anywhere from 1,500 to 2,500 rpm sometimes. Then sometimes it wont jump up at all. I did have a mail order tune done, so that may be part of the problem.
Old Jul 1, 2010 | 03:08 PM
squatingeagle's Avatar
Car: 91 Z28
Axle/Gears: 3.23 posi
check the vacuum line that comes out of the brake booster i believe it goes straight into the plenum. check it for leaks/splits or the o ring on the brake booster might be bad. had it happen to me before but my idle was a little more affected by it cause it was a severe leak
Old Jul 2, 2010 | 07:01 AM
1991 z28vert's Avatar
Had the exact same problem on my lb9 and it ended up being the vacuum diaphragm for the cruise control. take a look around there for any leaks from the lines or diaphragm.
gta90
Sep 15, 2015 04:00 PM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
kyleb24
Aug 15, 2015 08:24 AM
