Quick question in case anyone knows
Old Jun 27, 2010 | 09:13 PM
MarionCobretti's Avatar
Car: '91 Formula (semi-project)
Engine: 5.0 TPI
Axle/Gears: 3.42 Posi
So, my formerly rusty, basket case '91 Formula is up and running. However, there are many hackish things the P.O. did that I'm still trying to put right. Today, while installing new cap, rotor, plugs and wires (fun times!), I noticed what appears to be a vacuum fitting with no vacuum hose attached to it. I can probably dig through the manual and try to figure it out, but I was wondering, does anyone know what goes here, and where it should lead?
(I realize the picture is of a Corvette motor, but it gives the general idea--it's the same fitting)
Old Jun 27, 2010 | 09:26 PM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
Re: Quick question in case anyone knows
its nothing. not vacuum related. just a weird bolt.
Old Jun 27, 2010 | 09:34 PM
Engine: 5.7 LSX
ya man. mine has it too but on the passenger side. it has no hole if you look closely, its just a solid needle looking thing. pretty pointess but thats all it is.
Old Jun 27, 2010 | 11:50 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Actually, it does have a purpose guys. Ive seen many pictures of that bolt. It has a long skinny shaft or elongated clamp that sticks out. That skinny shaft or clamp is used to hold down the acc. cable/cruise control cable to prevent it from rubbing up agianst the underside of the hood.
NinjaNife
Aug 23, 2015 11:49 AM
crazynights
Aug 21, 2015 06:53 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
