stock fuel pressure
Old Jul 6, 2010 | 08:15 AM
matt1970pon's Avatar
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
Axle/Gears: 3.45 g92
stock fuel pressure
I just ordered a BBK adjustible fuel regulator for my iroc.The fuel pressure is at 85lbs right now and car is very fuelly and running horrible, so hence why the new regulator.What should I set the regulator at once I install?
Old Jul 6, 2010 | 08:33 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: stock fuel pressure
40 - 45 psi should be ok
Old Jul 6, 2010 | 08:35 AM
Twin_Turbo's Avatar
Dang 85, if you have multecs they will probably lock up on you, those black rochesters probably won't but no wonder it's running rich.
Old Jul 6, 2010 | 09:07 AM
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
yep..80 to 85.Sits at about 50 with key off. Then 80 with vaccum line still hooked up running.Very stinky.OK so I'll aim for 40-45 running i'm asuming.Thanks!
Old Jul 6, 2010 | 09:12 AM
Twin_Turbo's Avatar
45 ish w vac hose disonnected
Old Jul 7, 2010 | 09:42 AM
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
Thank you sir.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
