My TPI setup
Old Jul 10, 2010 | 12:46 PM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
My TPI setup
Well its finally done, I just have to install the fuel pump and its ready to fire up. Car was an LG4 non-cc carb'd car originally
Basic Engine Specs:
355 TPI SD
Painless TPI SD wiring harness
Bosch 36lb injectors
Holley 58mm Throttle Body
Comp Cams 08-305-8 276HR-14
Comp Lifters / Hardened Pushrods
PRW 1.5 Aluminum Roller Rockers
Edelbrock E-street Heads 64cc
Moates G1 Adapter
Base tuned using ACXN definition as a starting point
Old Motor:
New Motor:
Old Jul 10, 2010 | 12:51 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: My TPI setup
Looks sinister, diggin' the valve covers
stalkier
Dec 6, 2015 11:25 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
