lt1 injector replacement
Car: 89 formula
Engine: tpi 350
Axle/Gears: 95 z 3.42
so i put some used lt1 injectors in my car a while back and had a chip made for the computer to run the lt1 injectors, my question is if i want to replace the injectors which ones do i get, i was thinking that i need to get some lt1's again but didnt know if the boshIII would work with the computer set up like it is.. thanks in advance. also, do i set the psi any different when running the lt1 injectors vs stock?
Car: 1989 IROC-Z
Transmission: Th700R4
Re: lt1 injector replacement
The Bosch III 22lbs injectors from FIC will be a direct fit.
I would buy them from Jon anyday at FIC. Costs $169,99 3 years warranty, flow matched, and they have an exellent customer service and understanding. My thumbs up for them!
Link to the injectors : http://fuelinjectorconnection.com/sh...&productId=134
Car: 89 iroc
Engine: l98
Transmission: tremec
Car: 89 formula
Engine: tpi 350
does anyone know what psi the 24's should be run at?
Car: 89 iroc
Engine: l98
same as the lt1 the bosch 3 24 is the same as the lt1
