MAX RPM for modified 305 TPI
Old Jul 23, 2010 | 04:46 PM
TxTtopZ's Avatar
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
So given a modified TPI combination (stock type with aftermarket base, runners and port matched plenum) whats the highest RPM you can achieve while being in range of TPI with a 305? I have seen only seen 350/383 combo's. Shouldnt the 305 be a little higher due to being able to be fed more air given the cylinder size?
I used a calculator that says 461cfm for 5800rpm for a 305 @ 90% VE but I need something more relative, like port size = xcfm for 305ci/8...
Old Jul 24, 2010 | 11:28 PM
TxTtopZ's Avatar
Engine: 5 Liter 305
Axle/Gears: 3.45
Re: MAX RPM for modified 305 TPI
BUMP- No one knows what a bunch of hi flow TPI parts will do for the powerband on a 305?? Someone's gotta know.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
