whats the best way to swap to speed density
Old Jul 27, 2010 | 12:44 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i was told by many to just go with an aftermarket system like the fast ez self tuning or the commander 950. what do you guys suggest my maf system iis taking a **** and i want a better more reliable setup
Old Jul 27, 2010 | 09:40 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: whats the best way to swap to speed density
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
Old Jul 27, 2010 | 10:01 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yep get the 91-92 730 ecm and a map sensor and re-pin your existing harness. Its not all that difficult to do, just takes time to carefully remove pins from the connector and relocate them to the new position for the 730 ecm. Its the most cost effective way.
Old Jul 30, 2010 | 01:29 PM
sharkbait's Avatar
Car: 1975 Novamaro
Engine: 1988 305 TPI
http://www.larryselectricsite.com/TPIKIT.html
Lazy man's way to make the swap.
Steve78LT
Feb 24, 2016 12:15 AM
Keith5
Aug 27, 2015 04:37 PM
InfinityShade
Aug 22, 2015 08:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
86Base
Aug 8, 2015 01:34 PM
