Whats That?
Old Jul 27, 2010 | 07:02 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Whats That?
I found this sensor on my 85 305 TPI head. I cant remember if its the driver or pass side. Can anyone tell me what it is or what it does? Thanks.Whats That?-072700_1738-00-.jpg
Old Jul 27, 2010 | 07:18 PM
busterbrown's Avatar
Car: 1992 formula firebird
Engine: 355 TPI
Transmission: currently a T-5, eventually a T-56
Axle/Gears: 3:42
Re: Whats That?
looks to be a coolant temperature switch that operates the cooling fan.
Old Jul 27, 2010 | 08:31 PM
Damon's Avatar
Re: Whats That?
That style connector, which takes a female blade connector attached at 90* to the termina (as opposed to a straight-on blade connector) is telling me it's most likely the temp gague sender that would go in the driver's side cylinder head.
The pass. side head would be the aux. fan switch which should be either a straight-blade connector (older cars) or a single wire Weatherpack-style connector (newer cars).
In short, I don't think the connector type is the same on both sides and you should be able to logic this out if you look at the connectors sticking out of the wiring harness for each location.
Old Jul 27, 2010 | 08:45 PM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
Re: Whats That?
Yup, temp gauge!!
