engine ID
Old Jul 28, 2010 | 09:11 AM
matt1970pon's Avatar
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
Axle/Gears: 3.45 g92
engine ID
I'm trying to figure out what engine my iroc has in it. Its a 5 speed car so it should be a 305. Now the guy I got if from says its a 350.I looked behind the AC compressor and found no numbers,then looked behind alternator..again nothing. I want to put new injectors but need to know 19's or 21's. Can I get the number off the computer..will that tell me?If it has nothing on it could I put 19's in even if he was right and it is a 350?I would rather error on the smaller side then flood the engine.Thanks!
Old Jul 28, 2010 | 09:31 AM
Twin_Turbo's Avatar
Re: engine ID
Check the pass side stamp pad for a suffix or get a flashlight and peek on the bellhousing, drivers side, above oil filter. If it says 5.7 it's a 350
see where it says GM 5.7 here??
Old Jul 28, 2010 | 11:37 AM
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
Re: engine ID
I see it..I will check tonight.Thanks
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
