Distributor question in a 1986 IROC w/HSR
Car: 1986 IROC Z
Engine: 383/D1SC
Transmission: TH 700R4 or TH 7004R
Axle/Gears: Moser 9" 370:1
I have an HSR intake manifold on my 86 IROC that has the large GM distributor. I am trying to find a small (thin) distributor that will work with the 86 ECU. Do I have any alternative than to go to an aftermarket ECU?
Thanks for your help,
Steve
Steve
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Distributor question in a 1986 IROC w/HSR
MSD # 8366 if you have $$$
You need the adapter harness to convert your HEI plug to the smaller cap dist plug and a plug with pigtail to connect the remote coil
Forum member Mike at Eficonnection has the parts you need
http://www.eficonnection.com/eficonnection/default.aspx
Car: 1986 IROC Z
Engine: 383/D1SC
Thank you, I couldn't find the exact item you portrayed, so I sent sales an email.
Steve
PS. I do have the 8366 already and was thinking that I would need a different distributor.
Steve
mustangman65_79
Aug 11, 2015 03:17 PM
