what fuel pressure should I have?
Old Aug 8, 2010 | 02:59 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
305 tpi 91 z28 convertible. I hooked a gauge up to it and I have 25psi with the key on, no start. With the engine running at idle it's about 36psi, with the regulator disconnected it only goes up a couple more psi, never even close to 40psi. Does this sound normal?
Old Aug 8, 2010 | 03:30 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: what fuel pressure should I have?
NO With the key on and engine off 36/38 psi and engine running at idle 38/40 psi. That is what I have on my underhood mounted FP gage.
Old Aug 8, 2010 | 04:43 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
thanks. With the engine at idle the psi was 36. When I stabbed the throttle the psi would drop slightly. No leaks or anything and we didn't do a volume test.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
