Running in closed loop with 42lb injectors
Old Aug 13, 2010 | 04:22 PM
tslsa28's Avatar
Car: 91 RS and Jaguar XJS
Engine: ZZ383 with Mini Ram
Transmission: Tremec 3550
Axle/Gears: 3.42 with Tru Trac
I have a ZZ383 in a 1991 Camaro making about 390 rwhp/ 410 rwtq. I am using 42lb green top injectors at 40 psi with a Walbro fuel pump. It is tuned on a dyno and we have the full throttle tune just right. I have two questions, first is we still don't the start up lean enough and it doesn't start well when hot. Can the stock computer go lean enough with 42lb injectors to start well? Second question is my tuner wants to leave computer in open loop all the time as he feels the computer's small adjustments from reading the O2 sensor will make it "chase itself" when cruising in closed loop and the air fuel ratio will never stabilize. Any ideas would be apprciated. Thanks.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
