406 build
Old Aug 13, 2010 | 11:00 PM
aux187's Avatar
406 build
Hi Guys... My first time here. Great site I just hope I can get some questions answered. I got a 86 chevy truck 4x4 I also have a 406 engine not a hot rod and I also have a TPI system out of a firebird. Was wondering if I could use this System on this engine? All I'm doing with this truck is haul 4-wheelers and snowmobiles up the mountain. Stick to the carburetor or use the TPI System I got? What should I use for a cam? If swapping the carb? I want to get some good mileage and better cold starts. I will be running 3:73 gears with a T400. Any help would be greatly appreciated.
Old Aug 13, 2010 | 11:06 PM
jakester136's Avatar
Re: 406 build
I imagine if you could get the tpi setup to work it would save you a little gas going up the mountain and it wouldnt effect the way it runs as much as you increase in elevation on your way up as the air leans out
Old Aug 13, 2010 | 11:27 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: 406 build
Something like a Comp Cams 270'ish with the TPI would make a real nice tow motor. Probably only 325 or so HP @ 4K but around 500 ft/lbs or better and it would start at like 1400 RPM. That's why a lot of Jeep guys do the TPI for rock crawling and what not. LOTSA' low end grunt when set up correctly. And, it'll definitely beat the carb for easy starts and better mileage.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
ZEEYAA
Apr 16, 2023 08:29 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
