More info on tbi to tpi conversion
Old Aug 25, 2010 | 05:59 AM
driftcamaro128's Avatar
HELLO EVERYBODY. I HAVE '92 RS WITH A 305 TBI. IM DOING SOME RESEARCH ON A TPI SWAP. I THINK IM GOING TO GO WITH SPEED DENSITY.I WAS JUST LOOKING TO SEE IF ANYONE HAS DONE THIS SWAP AND HAS WELL DOCUMENTED IT. LOOKING FOR STEP-BY-STEP INFORMATION AND PRECEDURES FOR THIS SWAP.
Old Aug 25, 2010 | 06:19 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: More info on tbi to tpi conversion
I did this swap about 15 years ago on my 89 except I went maf not s/d. The best advice I can give you is to make sure all your parts come from a 92 donor car, so all the connectors will have the same pinouts on them.
You'll need to change the fuel pump, the throttle cable, the tv cable, you'll need an ecm and prom and engine harness from a 92 305 tpi car.
There's probably more stuff too, but thats what I can think of right now.
Old Aug 25, 2010 | 03:20 PM
Thanx John
MustangBeater20
Oct 29, 2022 09:20 PM
evilstuie
Jan 9, 2020 08:29 PM
junkcltr
Aug 2, 2019 11:12 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
